polyurathane motor mount inserts
Old 02-12-2013, 03:08 PM
SUPERBOOST's Avatar
Default polyurathane motor mount inserts
Anyone know where to get just the inserts or sleeves with inserts to build motor mounts?Like the sleeves brp uses in their mounts.
Old 02-12-2013, 03:15 PM
mille_3's Avatar
http://www.summitracing.com/search/B...FWaoPAodfEAAgg
Like this?
Old 02-12-2013, 03:38 PM
aknovaman's Avatar
http://www.autofab.com/bushings.htm
Old 02-12-2013, 05:06 PM
SUPERBOOST's Avatar
Originally Posted by mille_3
The ones from summit are the factory type,I want just bushings and tubes to fab my own mounts for better clearance.
Originally Posted by aknovaman
Thats the kind Ive been looking for!I could'nt find any anywhere.Not too bad on the prices either.Thanks for the link.
Old 02-12-2013, 07:00 PM
jmespe1's Avatar
I got mine from a local Spring Shop for $12 per pair. They are technically Leaf spring busings but they are the same poly material. You can see them at work in my build thread.
Old 02-13-2013, 07:41 AM
SUPERBOOST's Avatar
Nice ,you do some good fab work.Those make really good looking,strong mounts.The seats are killer,that will be a nice truck.
Old 02-13-2013, 08:27 AM
1981TA's Avatar
Ditto that. Poly Lower control arm bushings for 2nd Gen F-body (or any muscle car for that matter) will also give you some options.
Old 02-13-2013, 12:55 PM
bczee's Avatar
You might also try Speedwaymotors or Yogiinc as they have many parts or kits for making up parts for Hot Rods and Street Rods.
Try searching for Bushing or Motor Mount. But Control arm and other suspension bushing would work well..
BC
Quick Reply: polyurathane motor mount inserts
