Pick apart my setup...
Like to hear some opinions on the new build...
Stock LQ4/9 Bottom end
Heads- https://www.vengeancerd.com/ecart/pr...t-Dual-Springs
LS3 Polluter Cam
Mamo'd Fast 102mm
LS3 Polluter Cam
Mamo'd Fast 102mm
I dunno if its gonna happen man. I think you can get really close, but those ls3 heads on the small bore motors are just hit and miss the valve events gotta be perfect. And youre also gonna be ptv clearance limited, so you better check.
Then add an a4 with a stall, eating up more power.
