Vibration at certain RPM's, help please
I have an 01 z28, cammed, stalled th400 trans that has a pretty good vibration at certain RPM's sometimes its long and drawn out, sometimes its a quick shutter. Usually at 3500-4000 rpms in 3rd (dont know the exact speed, still working on getting the speedo and trans working together.)
Is this a driveshaft out of balance problem?
Any and all help is MUCH appreciated/needed.
It seems to me like you have a driveshaft problem, do you feel real hard vibrations? As if your car seems like it was wheel hopping? If it is, my truck was also doing the same thing at high MPH between 80-95. I would feel real scary as hell vibrations as if my driveshaft was gonna snap off. Soo I took it to my tuner and he told me my driveshaft was out of balanced. Soo I took it to get balanced about two weeks later and I rev'd it up again that same MPH as last time and there was no vibrations. It could be your U-Joints or a balance problem.
Tried revving in park and had no vibrations at any RPM's. So that basically means it has to be something in the driveshaft, correct?
Another thing i have noticed, when im cruising along the highway (65-70) if i have my foot on the gas a little, slight acceleration then the vibration is quicker, if i let off the gas and start decellerating then it is a more long and drawn out vibration.
Ill have a shop look at it monday. On the rims/tires i pulled off when i bought it, there was much more wear on the insides of the tires than the outsides.
