serious clutch chatter monster stage 2 10k miles
Does anyone else have this issue? Installed it last spring put 10k on the car all was good until recently. It sounds like a bag of broken seashells if that makes sense. Its just a bolt-on daily driver car so its well in its power range. Not knocking on monster but why is this happening?
The stage 2 should be quiet.
loctited all the bolts broke the clutch in properly. havent had the issue until recently. it only chatters during clutch engagement in first gear. so leaving from a stop is the only time a really hear it.
I also replaced the slave when i did the install. Could it be the slave chattering?
could something have broken inside the trans itself and cause the input shaft to wobble?....maybe pilot bearing failure?
OP, if a quick beating doesn't clear it up, you'll probably have to drop the trans and fill this thread with plenty of pics...i'd like to know what it is.
i just took it for a spin after class beat the ***** off of it. It seems to quiet down and stop once it gets warm. Im going to keep an eye on it, if it keeps doing it of gets worse ill drop the trans and get some pics of what i find
you sure that chatter isnt glaze on the clutch? because if something was loose, beating the hell out of it would definitely NOT help that issue.
i doubt anything is loose. I torqued everything to spec and red loctited everything. If something were loose of backing out i think it would chatter more than just during clutch engagement. Right now I am pointing my finger at the slave. I have a tick adjustable master that has a little dead space in the top of the pedal. As the it warms up the dead space goes away. If thats not the case Im going to pull the trans and take a look at the clutch itself. I will also bleed my clutch tomorrow and see if I can finally get the last of this dead space out and see if it helps. The dead space has been an ongoing problem for some time and the clutch hasnt chattered before so I never thought twice about it.
Clutch is continuing to chatter. Not getting worse. Im going to pull the Trans and check it out just don't know when since the weather around here is so on and off. This its my daily so its going to have to work around my schedule.
those tick perfermance MC are powerful units...where is clutch pedal relative to the brake pedal?...since everything was fine up until 10K i'm wondering if there's is too much hydraulic pressure being applied...
