g body starter question
I have a l92 swapped into my cutlass and it was starting and running great then the starter started to act up it would click and struggle to start then engine so I replaced the starter then it worked for a few starts then started to do then same thing. I'm not sure if maybe I caught a bad starter again or another issue
LS1Tech Sponsor
Check battery connection at starter. Check grounds from battery to frame and frame to engine. Lastly, check the battery charge.
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
would that cause it to like want to start the make a quick jump at starting the go back to a growling noise its a very hard noise to describe
LS1Tech Sponsor
If the noise you are describing is a starter that wants to turn, but is turning slowly, then yes.
Jon
PSI
Jon
PSI
__________________
Ebay Store
Ebay Store
