84c10 5.3/4l60e
Old 02-14-2013, 11:04 PM
84hernandezc10's Avatar
Default 84c10 5.3/4l60e
Well finally about to start my build. Found a 5.3/4l60e I've been lurking for awhile trying to gather all the info I can. Still needing info on what to do with trans cooler lines. I'm going to try and tackle the wiring harness myself I'm new to the ls motors so I will probably b asking a lot of questions
Attached Thumbnails 84c10 5.3/4l60e-image.jpg
Old 02-14-2013, 11:06 PM
Tired 350/350
Old 02-15-2013, 06:35 AM
LS1Tech Sponsor
BP Automotive's Avatar
You will definitely love that vortec compared to that old 350! Ill be watching your thread! This swap is a fairly straight forward swap. The radiator from the newer trucks could very well be a straight swap. If not you can always just use an aftermarket trans cooler!
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old 02-15-2013, 06:53 AM
ls1nova71's Avatar
If you had a 350 turbo before, what did you use for a cooler for it? The cooler in the original radiator will work unless you're going to be putting a stall in it or pulling a trailer alot.
Old 02-15-2013, 08:06 AM
The connections on the trans look like a slip fit connection and I wasn't sure if I could use the same lines I have now or ill need new connections and lines. It's going to be a stock swap for now no kind of stall. I was wanting to use the stock radiator
Old 02-15-2013, 08:24 AM
ls1nova71's Avatar
You can take the quick connect fittings out of the transmission and replace them with the flare fittings out of your old transmission.
Old 02-15-2013, 08:46 AM
Ok sounds good. That marks one more item off the list. Here's a pic of the new motor
Old 02-15-2013, 08:56 AM
Ordered some parts for the swap. 87 tank and sending unit, fuel lines and corvette filter regulator, lt schoenfeld headers, tac module. Hope all my parts come in by the time i get back in town. still needing the PCM and starter and alternator. Probably going to check the jy here in Lubbock before I go back
Old 02-15-2013, 01:09 PM
Ls1nova I read through your build its looking good I wish there was a jy close enough so I could go the budget route. I like the oil pressure idea might have to try it. Is the oil pressure not needed for the computer to work properly?? The orange and blue trucks are bad a$$ you do awesome work
Old 02-15-2013, 04:34 PM
sweetk30's Avatar
lots of stuff i did in mine sofar . hope my info helps you get rollin . https://ls1tech.com/forums/conversio...post-45-a.html
Old 02-15-2013, 06:10 PM
I like the dbw pedal mod might have to try it
Old 02-15-2013, 06:18 PM
gagliano7's Avatar
The oil pressure isn't needed for the computer.
Old 02-15-2013, 06:42 PM
Ok Thanx.
What is everyone doing for the harness?? Connections soldering??
Old 02-15-2013, 09:33 PM
LS1Tech Sponsor
psiconversion's Avatar
You can either rework your harness (pictured) or purchase a standalone. Do you have the DBW components (Throttle body, TAC Module, TAC Harness, Pedal)? That may weigh into your decision due to cost.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 02-15-2013, 09:39 PM
Well I actually just ordered the tac module from your company. I have the throttle body and pedal.
Old 02-15-2013, 09:42 PM
LS1Tech Sponsor
Ok. Do you have the TAC harness? Are you going to rework the engine harness in your picture above or buy new?
Jon
PSI
__________________
Ebay Store
Old 02-15-2013, 09:48 PM
Yes I do have the tac harness off the pedal. All was needed was the tac module. Well I'm going to attempted it. Found lots of info just not sure about the splicing and soldering of the wires. If it doesn't turn out right I will probably order new. Just wanting to do it myself
Old 02-16-2013, 06:20 AM
LS1Tech Sponsor
Sounds good. Module is shipping today. If you have questions when you get it please let us know.
Jon
PSI
__________________
Ebay Store
Old 02-16-2013, 09:43 AM
Ok will do Thanx
Old 02-16-2013, 12:00 PM
ls1nova71's Avatar
Thanks for the compliments. I guess I take for granted how many U pull it type junkyards we have near here, lucky I suppose. Also as mentioned by someone else, the oil pressure isn't needed by the PCM for the engine to run, at least not in the older engines. Good luck with your project, the first one is always the hardest, but also the most rewarding!
Quick Reply: 84c10 5.3/4l60e
