Irritation
Old 02-16-2013, 04:17 PM
wings66's Avatar
Default Irritation
ok fellas i have a question. 95 z28 6sp. Can the ecu or pcm be programmed to the cam i put in it?
Old 02-16-2013, 04:19 PM
wings66's Avatar
the cam is a comp cam 290 duration with a .51 lift
Old 02-16-2013, 05:21 PM
bad_408_vert's Avatar
Yes you can.
I 'd start by reading here. https://ls1tech.com/forums/pcm-diagnostics-tuning-7/
Old 02-16-2013, 10:00 PM
96z28_lt1's Avatar
very tuneable, just finding someone to do it is the issue, dyno tunes are prefered to mail order tunes. but price and availability is always a figure in deciding
Old 02-16-2013, 11:15 PM
96capricemgr's Avatar
So you bought a Com 7-306-8 cam without first doing some research about supporting mods?
Do yourself a favor and return the cam if you can, and if you can't, put it in a closet for a year while you begin to grasp the basics and plan supporting mods.
Old 02-17-2013, 12:34 AM
Catmaigne's Avatar
Go to IKEA and make yourself a nice but overpriced reading lamp. I suggest you also pick up a copy of All The Knowledge in The Known Universe Pertaining to LT1 Engines by LS1tech and give it a good read. If your head doesn't explode you can go ahead and cam your car.
https://ls1tech.com/forums/lt1-lt4-m...ion-guide.html
Quick Reply: Irritation
