Dying when taken out of park
Old 02-18-2013, 01:30 AM
z28master's Avatar
Default Dying when taken out of park
I just bought a 99 ws6 and when i pull it out of park into rev. Drive etc. It dies once running its fine til the next time i pull it out of park my dad thought it might have been a ground undone and indeed i found one undone but didnt seem to help.... any ideas? Also i have two guages one is trans temp and other is air /fuel and the air/fuel is not working they light up but just doesnt show where its at (lean,rich etc.) Ideas? Thanks
Old 02-18-2013, 03:57 PM
WarShrike's Avatar
^Fouled wideband sensor or not connected.
As for it dying, did you check for vacuum leaks? Do you have weak brake pedal or really firm? I remember somebody having this issue but can't seem to remember what fixed it.
Old 02-18-2013, 04:00 PM
ss performance's Avatar
I had a simular problem. Turned out to be a bad battery. I know it sounds wierd but when I changed the battery problem went away.
Old 02-18-2013, 08:37 PM
z28master's Avatar
Thanks guys, im gonna try changing the battery cause the first thing i did when i bought it was change out the battery with my truck battery since the one in it was dead and my truck battery is nearly seven years old. So.....good point. Thanks!
Quick Reply: Dying when taken out of park
