wastegate vacuum hose/ rear mount
Ok do I run my line from my wastegate to the compressor on turbo or manifold. If to manifold do i just block off barb on compressor. Also its a rear mount if it maters
i have the bottom port on my wastgates going to the the turbo housing. but i have my boost controller sensing boost at the IM.
so basically i have mine setup to control the boost that the motor sees but useing the higher pressure at the back of the car to help hold the gates closed
-alex
-alex
