Stall Wall
Old 02-19-2013, 03:36 PM
NewOrleansLT1's Avatar
Default Stall Wall
Ok so I went from a 3500 stall to a 4000 stall and hit Stall Wall. The car was tuned for the 3500. Someone told me that the tail shaft flexes on the tranny and cause this. If I relocate the torque arm OFF the tranny would this fix the Stall Wall problem?
Old 02-19-2013, 03:56 PM
quik95lt1's Avatar
what!? no!!! lol........but relocating the tq arm is a good idea anyway.........retune the shift points and problem solved
RamAir95TA's Avatar
No, that will not fix the problem. Only retuning shift points will.
Old 02-19-2013, 04:58 PM
Gotcha.. I don't know much about this issue. So if my stall is 4000 I have to get the VSS set to 4000?
Old 02-19-2013, 05:27 PM
9-Second Club
Ed Wright's Avatar
With just a 3500 you might get by with just screwing with the WOT shift MPH. Depends on how much your converter slips. Converters aren't all created equal.
I hacked the OS a few years ago. My 4500 converter didn't even needs the WOT shift MPH screwed with after that. Have seen a few that still needed the shift points screwed with too. Those were so loose neither "fix" would work alone.
Old 02-19-2013, 07:09 PM
Ed I'm going to set an appointment with my tuner and see if he can fix this. But I really would like to get in touch with you if he cant fix this. Are you running a shop?
Old 02-19-2013, 07:22 PM
9-Second Club
Ed Wright's Avatar
Working out of my home now. Who is your tuner?
Old 02-19-2013, 07:26 PM
Geoff at Engine Power Systems (EPS) in Baton Rouge, LA. Do you take Mail Orders?
Quick Reply: Stall Wall
