Flywheel bolts threaded?
Old 02-20-2013, 11:07 AM
thefridgews6's Avatar
Default Flywheel bolts threaded?
Are the bolt holes on the flywheel threaded or should the bolts just slide in and out, trying to determine if I need a new flywheel after my bolts backed out
Old 02-20-2013, 12:02 PM
nomasterase's Avatar
no the holes in the flywheel are straight thru but check the holes in the crank and put some loctite on when you reinstall so you dont have an oil leak out of the crank
Old 02-20-2013, 12:24 PM
I'm guessing red lock tight
Old 02-20-2013, 12:29 PM
And thanks by the way
Old 02-22-2013, 03:56 PM
99wssixm6's Avatar
If you dont put loctite on the bolts leaking oil will be the least of your worries.
Old 02-23-2013, 11:09 PM
i used blue on mine since ill probably have to remove them again
Quick Reply: Flywheel bolts threaded?
