Good stall for supercharger
Old 02-20-2013, 06:11 PM
bigantws6's Avatar
Default Good stall for supercharger
It's a 2008 corvette a6 ls3 with Vortech v2-si looking to do a stall what stall speed would be the best for boost it just got a lingenfelter 2step launch ......the 60ft is killing the time
Old 02-20-2013, 06:43 PM
bigantws6's Avatar
Old 02-21-2013, 10:09 AM
Circle-D's Avatar
A centrifugal supercharger needs some rpm to keep it happy, so a stall converter will make a huge difference. We typically do ~3000-3500 range depending on how aggressive you want to get. Can you send me an "Ask Chris" form with all our specs and I can help spec you a custom converter. Link is in sig.
Thanks,
Chris
Old 02-21-2013, 12:32 PM
Blackpanther99's Avatar
Yeah ill stay around the 3500 area as mentioned by Chris. Badass setup too.
Old 02-22-2013, 04:37 PM
LS1Tech Sponsor
FTICONVERTERS's Avatar
Big, I would want to be in the 32-3400 range in a triple clutch format. Prolly a 10.5" with a CNC stator in it machined for your combination!!!
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old 03-08-2013, 02:41 PM
bigantws6's Avatar
really leaning toward the 3200
Old 03-08-2013, 03:25 PM
Burken01's Avatar
You can always restall your conveter for free if you buy from a sponsor, that way you can experiment while perfecting your combo.
I just got a circle d stall, chris has excellent customer service and will set you straight.
Old 03-09-2013, 10:44 AM
I8UR4RD's Avatar
The way I did it was, when stalling I wanted to launch closer to peak torque for better 60 foots. I looked at a ton of dyno sheets and found the centri setups making it later in the powerband
So I went 4000-4200 to get me closer to that torque of the line. It's a triple from circle D whom I highly recommend.
Old 03-09-2013, 05:27 PM
john563's Avatar
thats interesting..i thought that be too high..i have circleD 5c and its in that range but thought it was a N/A(inmy case N/A 100 shot) converter
Quick Reply: Good stall for supercharger
