Oil pan advice
Oil pan advice
I am in the middle of replacing my stock lq9 truck oil pan with the GM muscle car pan kit. I measured pan to pickup clearance and its an unacceptable 1 and 1/16 of an inch!!! Wtf is GM doing? Good thing I am **** and always check. I triple checked and even had my brother measure it to make sure I'm not crazy. Well, not in this case anyway.
IMHO my two options are: weld a small extension on the pickup tube to get 1/4 to 3/8 clearance or buy the f body pan kit and have my exhaust guy rework my Y pipe to clear it. I measured and it would be really close and would probably hit the pipe the way it is. What do you think is the best option???
I am open to other suggestions so please share.
Thank you!
Thank you!
LS1Tech Sponsor
May have missed it, but what is this going in?
Jon
Psi
Jon
Psi
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
Clay it to be sure(just like doing PTV Clearance)
you may just need to buy a pan spacer(which I'm not sure if one is made for that pan...but there are LS oil pan spacers made that may work correctly..same bolt pattern)
or cut/weld the pickup tube as necessary to make it to your personal requirements.
Wouldn't a pan spacer make the clearance wider? Think I'm just gonna order the f body pan and return this POS. I've read posts of other people having the same issue and I have way to much money in this motor to risk blowing it over a difference of $100. Agreed?
sorry...my bad... I just saw the 1/16 inch
didnt see the 1" part of it....
yes... only option is adding more tube or getting a different one
should be more like 3/16 of an inch for oil pan to pickup
also, are you using the correct pickup for that pan???
you cant just change the pan and not the pickup tube....both are a set...sometimes the windage tray is also part of the oil pan pickup picture..
The pan came as a kit with the windage tray and pickup. I really dont have much of a choice because i actually tried the truck pickup but as i expected itdidnt work. I read on here about this problem so i called a dealer for GM perf parts and they said they never heard of this issue. That pisses me off!
Oh well whats done is done. Just ordered the f body pan, pickup etc from an ls1 tech sponsor. Maybe ill get lucky with the exhaust but i doubt it. Lol
Thanks for the help!
check with Canton. I know they have started coming out with a bunch of different LS pans. I'm not sure if they would suggest buying their pan and pickup combo or if there is a pickup they have that might work for you. Just my .02 cents.
