Punched a hole in my Bazooka...
Old 02-20-2013, 08:45 PM
kjcmusic17's Avatar
Default Punched a hole in my Bazooka...
So, while installing my bazookas today (using self tapping screws), my hand slipped and the drill went through the edge of the sub
The tear is REALLY small. About the width of my pinky nail. My dad told me to seal it from both sides with liquid silicon, but I thought I would check here first.
The last photo has me putting a little pressure from the back so you can see the definition of the tear.
PICS Y U NO WORK?!
https://plus.google.com/u/0/107242565503071210534/posts
Old 02-20-2013, 08:54 PM
tsheehan's Avatar
Man that's rough
super glue the tears don't worry about it.
They are paper type or synthetic?
plenty of speaker cones have extra glue blobs on them it should not effect them
Old 02-20-2013, 08:59 PM
Cajun ELESS-ONE's Avatar
i have a 8inch bazooka sitting in my room if you want it lol. dont need it. pm?
Old 02-20-2013, 09:12 PM
kjcmusic17's Avatar
It's gotta be a 6.5" for the sail panel. It's actually in the suspension, not the cone.
Old 02-21-2013, 02:55 AM
fspeedster's Avatar
If the puncture is in the surround you can use black rtv silicone to seal it up. Make sure you seal it both on top and underneath. It'll work like new. If you want something different i have some 6.5" KICKER subs that I'm trying to get rid of.
Old 02-21-2013, 03:55 AM
Daniel Richards's Avatar
PICS Y U NO WORK?!
Pictures don't work because there Google+ images, Google+ is not Forum friendy, only your friends on Google+ can see them.
but as Stated RTV is the best option to fix the surround, make sure and give it time to cure. also why are you using a cordless drill for installing the 6.5's, thats a screw drivers job, only time a DRILL should be NEAR a speaker is installing the screws for the SUBWOOFERS (not sail panels) into a WOOD box, mounting to factory locations shouldn't be done with power tools.
Old 02-21-2013, 09:32 AM
Save the manuals!
wssix99's Avatar
I wouldn't advise trying to repair them until you can post pictures we can see. I tore mine a bit when I installed mine and they are perfectly fine. The suspensions are really strong and can take small tears.
If you put extra weight (from a repair) on the suspension, it will throw your sound off.
Old 02-21-2013, 09:29 PM
kjcmusic17's Avatar
The bazookas don't quite reach the factory drilled holes. So power drill + self tapping screws = fix. Except really, it equaled slipping and breaking stuff.
Old 02-21-2013, 10:28 PM
Save the manuals!
wssix99's Avatar
I guess you didn't see this thread first, warning about ripping the suspension???
https://ls1tech.com/forums/stereo-el...ll-w-pics.html
Old 02-22-2013, 09:18 AM
kjcmusic17's Avatar
Actually, the first time I installed them 2 years ago, I had. I don't remember why I didn't go that route, but I had a reason, hence the self-tapping screws.
So a google search recommended permatex ultra black on both sides of the suspension. Thoughts?
Old 02-23-2013, 11:36 AM
J_O_E's Avatar
I punched a hole into the center of mine once and put some electrical tape over it. Been bumping hard for months. But, if you can glue a little piece it'll work.
Old 02-25-2013, 09:16 PM
kjcmusic17's Avatar
The Permatex Ultra Black worked GREAT. Sealed it up, let it sit for 12 hours, installed it, pushed the system pretty hard, didn't even budge. No difference in sound quality as far as I can tell.
Old 02-25-2013, 09:28 PM
Save the manuals!
wssix99's Avatar
Did it sound bad before the repair?
Quick Reply: Punched a hole in my Bazooka...
