View Full Version : can I lower fuel pressure
patSS/00
04-19-2004, 03:41 PM
Anyone know if you can lower the fuel pressure by putting a resistor into the power line going to the fuel pump?
Chris99WS6PWTMET
04-20-2004, 09:08 PM
Why would you want to do that? IMHO that would be just asking for a possible lean condition on the "big end" and possibly some burned pistons. An adjustable regulator is a much safer alternative.
slow
04-20-2004, 09:31 PM
NO.
why do you need to lower it?
Ryan
MIGHTYMOUSE
04-21-2004, 03:42 PM
the correct way to lower it is by adjusting the 'fuel pressure regulator' :)
patSS/00
04-23-2004, 12:22 PM
Lowering fp would be to accomodate different injectors (sort of a rough initial tuning). As for a regulator, doesn't that require either (a) getting into the fuel tank, or (b) having a new return line back to the tank? If there's a way to have a regulator in the engine compartment without added new lines please let me know!
