VP Q16 racing fuel
Old 02-24-2013, 02:22 AM
baezi z06's Avatar
Default VP Q16 racing fuel
Hi
has any one used this fuel
itīs hard to get racefuel here in Iceland but i can get a barrel of VP Q16
Q16 will work well in any drag racing application -- naturally aspirated, nitrous or blowers. Q16 is highly oxygenated, requiring a 4-6% increase in fuel flow, which will make 3-5% more power than competitive 116 octane fuels. Q16's oxygenation will significantly expand the range of air/fuel ratio acceptability, so performance will be more consistent and won't vary as dramatically with altitude or density changes. For bracket racers, variations in ET from run to run will be substantially reduced. This added fuel flow also effectively increases its octane by 6-8 numbers above its standard ASTM octane rating.
http://www.vpracingfuels.com/vp-drag-racing.html
iīm thinking of it for my standalone fuel cell
Baezi
Old 02-26-2013, 09:06 AM
ATVracr's Avatar
We have used it before.
It is not a great fuel for nitrous.
Stick with C16.
Old 02-26-2013, 10:09 PM
BOOSTEDcatfish's Avatar
why didn't it work well for nitrous?
I plan on running e85 in my stand alone, mainly just theres a pump right down there road. and we have a TT car that runs e85
Old 02-27-2013, 09:44 AM
ATVracr's Avatar
E85 is not the same as Q16.
Q16 work very good for boosted cars.
Nitrous brings its own oxygen it doesnt need an oxygenated fuel to help it.
Made the tune up more sensitive, not what you want.
Old 02-27-2013, 10:18 AM
Sales@Tick's Avatar
Agree nitrous and oxygenated fuels aren't the best mix.
Old 02-27-2013, 01:58 PM
06X6spdGTO's Avatar
C16 or VP110???? For shot >200???
Old 02-27-2013, 02:47 PM
Torque_SS's Avatar
ohh **** i might need to switch to c16 the shop that tunes my car recommended q16 then ended up putting vp import in my stand alone gonna need to have a word with them any mods give more info on this subject i am looking at putting a 200 wet shot on my stand alone nx kit i know the vp import is even more oxygenated then q16 which is what i had in there before i wish i would have known this before i had them tune the car what a shop
Old 02-27-2013, 04:49 PM
Sales@Tick's Avatar
Depends on compression, but 110 should be just fine.
It's not like it will blow your engine up or anything like that, but it is a lot more sensitive to fueling and timing changes. It just isn't the best gas to run with nitrous.
Old 02-27-2013, 06:12 PM
06X6spdGTO's Avatar
Martin. 10.7:1 static.
Debating on what to buy for my standalone. Stuck with 91oct here in Nebraska.
C16 is 17.74 per gallon here.
I got jets from Neal for 200-100 n2o size and close corresponding jets for low pressure standalone and C16. I'm guessing AFR will still be targeted around 11:5 WOT on the spray the spray
Old 02-27-2013, 10:31 PM
Sales@Tick's Avatar
I normally target at least 12.0:1 afr on nitrous and majority of the time 12.5:1 afr.
Old 02-27-2013, 11:05 PM
06X6spdGTO's Avatar
With C16/VP110 or even pump gas???
Old 02-28-2013, 07:32 AM
ATVracr's Avatar
Yes.
They each require different timing but the A/F should all be pretty close.
If you must try Q16 that is the only one I would run a little richer.
Old 02-28-2013, 02:56 PM
Sales@Tick's Avatar
Yes.
Ditto.
Lean is mean!
Old 02-28-2013, 08:16 PM
SC_Titan's Avatar
used Q16 on my old zx14 with an 80 shot. Q16 made more power on motor than C16. That was the only advantage for me.
Old 02-28-2013, 10:05 PM
I knew that, but after reading these post ive learned a lot more
Old 03-01-2013, 12:11 AM
Dirty Vegas's Avatar
I was reading this thread thinking the exact same thing. zx14 on the same shot with the same fuel. Picked up 3 tenths over pump gas using Q16 on motor. Wideband was dead on through the last 2 months of the season, and we tested in 30-90 degree weather. All we ever adjusted was the progressive to bring more spray on sooner, as the rider was more comfortable with it.
Old 03-01-2013, 07:27 AM
ATVracr's Avatar
It will make more power on motor... it is bringing extra oxygen to the party.
It will work fine for smaller shots but like I said it makes the tune ups more sensitive.
There is a reason NO ONE that sprays alot of nitrous uses it. If it made more power or worked better they would and we would have stuck with it if it did.
We didnt just try it once, we used it for about 1/2 a season.
Old 03-01-2013, 05:32 PM
Sales@Tick's Avatar
We run C16 and C23 on all of our nitrous cars.
Old 03-01-2013, 09:47 PM
ATVracr's Avatar
That's what I would reccomend... C23 for anything over 300ish
Old 03-02-2013, 11:17 AM
Sales@Tick's Avatar
We've added a good bit of compression to our shop car and we may have to run c23 all the time now. Lifted a head and burnt number 7 at the sb nitrous nats last year getting after it.
Quick Reply: VP Q16 racing fuel
