What to do to fix cracked pump th400..
Old 02-24-2013, 06:52 PM
superbean's Avatar
Default What to do to fix cracked pump th400..
I have a used th400 that I was just going to slap a pump seal and tailshaft seal in and run temporarily.. but when I removed the torqueconverter/pump seal part of the pump has a pea sized hole in it. This may sound dumb, but will it hurt anything to run like this? It is before the seal, so I wouldn't see why it would leak.
Here is a pic I found on the net describing where the hole was
As looking at the backside of the pump, there isn't a way for fluid to get there anyway..
Then I found this picture online, exactly what It looks like.. maybe it's supposed to be there?
Old 02-25-2013, 09:42 AM
72blownvert's Avatar
That is normal. Your all good.
Quick Reply: What to do to fix cracked pump th400..
