Trick of the week on oil pump?
What's the latest trend in oil pumps? Did we learn that L92 truck pumps are similar/same as the desirable LS6 pump? Little clean-up port work, shim spring for pressure and good to go? ..or stick with classic fall-back melling unit? Going in gen IV LS3 based build that will see some revs.
Thanks,
TJ
Thanks,
TJ
