1000 rwhp turbo motor
Category: Engine - Complete Motors
Price: $0
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO
Location (State): MS
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Its internals are as follows
-410ci GenIII Ls1
-LQ9 iron block-decked,cylinder honed to 4.040 with torque plate, mains align honed
-Diamond IBF custom race pistons-thermal and friction coated, tool steel pins, 4.04 bore
-NEW Dragon slayer crank 4" -smaller 2" rod journals for less bearing speed
-Callie's 6.125 h-beam rods-smaller 2"journals,arp 2000
-AFR 225 4" bore heads-inconal EV's, new seals, spring upgrade, stock rockers
-j&j Custom Cam-Motion camshaft
-Comp cams hardened pushrods
-double roller timing chain
-ARP main and head studs
Engine was completely freshened at Performance Engine Works of Tupelo.
All new rings, lifters, bearings,oil pump
ALSO INCLUDED is Airwerks turbo-t6 flange, 1.3 a/r turbo has been refreshed.
Best way to reach me is text. 601-416-41one7
IF you need some more info call or text. Thanks
