9.0h at 150 tc78
Old 02-25-2013, 06:19 PM
6.0mustang's Avatar
Default 9.0h at 150 tc78
i thought i had posted this but i couldnt find it.
my last trip to the track, car was maxed out on 21lbs. it was falling off on the big end, i was going to set it up to lower boost after a given rpm but i broke a ujoint shortly after.
1.35 60ft
5.74 @121 1/8
9.05 @ 150 1/4
Old 02-25-2013, 06:44 PM
SKULL's Avatar
damn...
Old 02-25-2013, 07:01 PM
MUSTANGBRKR02's Avatar
Car moves out!
Old 02-25-2013, 07:07 PM
lunati397's Avatar
very nice
Old 02-25-2013, 07:13 PM
lunati397's Avatar
what setup are you running heads cam trans ect
Old 02-25-2013, 07:42 PM
Camaro9969's Avatar
Wow that car launches great!
Old 02-25-2013, 08:13 PM
drumbo87's Avatar
Specs!!!!!!!!!!!!!!!!PLEASE!!!!!!!!!!
Old 02-25-2013, 08:50 PM
6.0mustang's Avatar
sorry for delay, its stock 317s. prc valve springs, tial 44 waste gate, 2.5 cross over, 4inch down pipe, edelbrock xt pro flo, comp turbo cam 235 231 @.050 .621 .617 115, the stall is a little tight suppose to be 3800 foot brakes to about 2600 is all, it works great so i dont mess with it, th400. 3.31 gears, 28x10.50. ebay 4inch IC. 1.15ar
Old 02-25-2013, 09:20 PM
I8UR4RD's Avatar
Originally Posted by 6.0mustang
sorry for delay, its stock 317s. prc valve springs, tial 44 waste gate, 2.5 cross over, 4inch down pipe, edelbrock xt pro flo, comp turbo cam 235 231 @.050 .617 .621 115, the stall is a little tight suppose to be 3800 foot brakes to about 2600 is all, it works great so i dont mess with it, th400. 3.31 gears, 28x10.50. ebay 4inch IC. 1.15ar
how much does it weigh?
Old 02-25-2013, 09:23 PM
78buturbo's Avatar
That's a damn good 60 foot for leaving at 2600 I see a 8sec pass in the future, I'm also wondering what it weights?
Old 02-25-2013, 09:24 PM
Ryans99ls1's Avatar
Assuming its still a 6.0 from your username?
Old 02-25-2013, 09:26 PM
Wicked69's Avatar
Is it a stock bottom end or built. That thing was haulin the mail.
Old 02-25-2013, 09:44 PM
6.0mustang's Avatar
ya its eagle h-beams and .005 weisco -11 dish pistons. trans brake 2 step leaving at 4k, it will do 1.50 60ft on foot brake. low 9s.
weighs 3000lbs on empty fuel tank an me in it. it needs adjustabe front shocks. that was on 25 degrees of timing.e85
Old 02-26-2013, 01:31 PM
AR_LSX_Stang's Avatar
DAMN! That gives me hope for my t76 5.3 foxbody. Hows the Proflo? Is that a custom or ots cam? Sick numbers!!
Old 02-26-2013, 03:35 PM
6.0mustang's Avatar
I don't believe I am at the flow or air speed to see air distribution problems with the proflo plugs are consistant. Its an OTS cam.
Old 02-26-2013, 03:46 PM
LS1Tech Sponsor
hellbents10's Avatar
More then likely injector imbalance then the intake, but dang nice times!!! Cool car and setup for sure.
Old 02-26-2013, 04:01 PM
bozzhawg's Avatar
Bad ****!
Old 02-26-2013, 07:02 PM
6.0mustang's Avatar
leaving on idle
thanks for compliments.
Old 02-26-2013, 08:36 PM
6.0mustang's Avatar
not sure what your talking about
Old 02-27-2013, 07:24 PM
Beatdown Z's Avatar
Awesome ride!
Quick Reply: 9.0h at 150 tc78
