12.5" slicks
Old 02-26-2013, 09:24 PM
F0x Slaughter's Avatar
Default 12.5" slicks
Figured I'd post here and get quicker replies.
Will a 12.5" slick fit under the rear with a 10" rim and 7.5" backspacing?
Or will it require rolling the fender and possibly a BFH.
Old 02-26-2013, 09:48 PM
RamAir95TA's Avatar
It depends on the sidewall height. A 12.5" tire is equivalent to a 315. MOST 315s do require some fender rolling, bumpstop removal, etc.
The only need I see to run a slick that wide is either A.) You have a bazillion horsepowers or B.) You have a poorly setup suspension.
No reason you can't get the traction you need on a MUCH smaller tire IF the suspension is dialed in properly, which is FAR MORE IMPORTANT than the tires.
Old 02-26-2013, 09:57 PM
The reasons why I got 12.5" is because the 11.5" is not recommended for a 10" inch rim?
http://www.summitracing.com/parts/mtt-3755/overview/
These are them.
http://www.summitracing.com/parts/mtt-3754/overview/
Here is the 11.5"
Starting to wondering if I should exchange the 12.5s.
I have no rear end in my car right now, still have till next week before it ships, so I can't test fit them.
Old 02-27-2013, 05:57 AM
BIGCAT7274's Avatar
Wolfe racecraft minitub and it will fit.
Old 02-27-2013, 06:04 AM
bufmatmuslepants's Avatar
Considering guys with 2000 hp are going low 6s in the 1/4 on a 10.5 inch tire, I think 12.5 is overkill for your setup and will look poserish.
Old 02-27-2013, 06:30 AM
Will a 10.5 tire fit a 10in rim?
Old 02-27-2013, 06:33 AM
RamAir95TA's Avatar
I used to run a 26"x10.5"x16 on an 8" wheel. Can't comment on whether it will fit on anything wider than that.
Tire rack has a great section saying the max and min rim width for the specific tire.
Old 02-27-2013, 06:39 AM
I've run a 26x10.5x16 and a 27x10.5x16 on 8" salad shooters. Why are you stick on this 10 inch wheel?
Old 02-27-2013, 06:51 AM
9-Second Club
Ed Wright's Avatar
If you made more power and used a Trans brake you would understand. A foot brake ten second car needs nothing more than a set of nine inch radials.
Old 02-27-2013, 06:52 AM
RamAir95TA's Avatar
I was being facecious.
Old 02-27-2013, 09:01 AM
I mean I could send the 10in rims back and get a smaller rim.
Old 02-27-2013, 09:04 AM
What about a 9in with a 11.5" slick?
They don't make a 10.5 et street
Old 02-27-2013, 11:36 AM
9-Second Club
Ed Wright's Avatar
Originally Posted by F0x Slaughter
What about a 9in with a 10.5" slick?
Don't use a narrower wheel. Use the 10" wheels with those tires. My 10.5" tires were faster on 12' wheels. I have my 12.2W MTs (Just under 13" wide) in 14" wide wheels.
Old 02-27-2013, 12:06 PM
So I should just exchange the 12.5 for 11.5 or 10.5? I cruise on the weekends so I kinda wanted a DOT tire so I don't get pulled over for that.
Also the wheels are 10.275" weld rts
Old 02-27-2013, 12:23 PM
quik95lt1's Avatar
i gotta ask why in gods name do you want to run a 12.5" slick?
Old 02-27-2013, 12:49 PM
Because 11.5 wasn't recommended on a 10" rim and they don't make a et street 10.5"
In 28in tall.
I will be running 4.10s possibly nitrous. Was recommended for a 28in tall tire.
I think I'm going to exchange for a 10.5". But 28" or 26"?
Old 02-27-2013, 03:13 PM
duh
duh's Avatar
I would say a 275/60r15 drag radial would be perfect for you. It'll fit a 10" wide wheel just fine and give you your 28" tire. And you can drive them anywhere. M/T sells em
Old 02-27-2013, 03:41 PM
What do you mean they don't make a 10.5" et street? What have I been using the past 4 years? Why do you want a 28" tire? Once again, you don't have enough hp. Gregrob was spraying a 200 shot on a LE trickflow headed 355 and had to downsize to a 26" tire because 28 was too big and he just bogged. Who is giving you this tire advice?
Old 02-27-2013, 06:18 PM
I've posted a few threads on here and some respected guys recommended this stuff.
Gregrob told me 28".
Search the topic gears for nitrous.
Quick Reply: 12.5" slicks
