cheapest way to spray 250-300?
Old 04-19-2004, 08:32 PM
taqwache's Avatar
Default cheapest way to spray 250-300?
i been hearing of people having sucess with people spraying a 250-300 though the intake with a TNT or NX MAF kit. with my high 300 or low 400 RWHP car and with this much spray all i should need is a F-pump since it will be all wet. something like a 340L or 420L for about $350. now, i can find a F2 all day long for pretty cheap used like $400 or $500. so if i luck out i can spray a 250-300 for around $800. i already have a seperate low pressure fuel system for N2O so i can also do a DP also. or i can just get a F2 and use the low pressure fuel system i already have. ofcoarse i would still have to buy different fuel jets for it though. does anyone know of a cheaper way to do this? let us all know.
Old 04-19-2004, 09:59 PM
SMOKINV8's Avatar
From everything I have read, it sounds like you've got a good handle on it. I guess we talk to people in different circles though, I haven't heard of many people spraying over 200 through the MAF.
The one thing I will say... with nitrous systems, going with the cheapest alternative isn't always the best. Especially with as much nitrous as you're planning on flowing through there. Best of luck with it, should be interesting to hear your results!
Old 04-19-2004, 11:23 PM
bodhi's Avatar
I'm no nitrous guru, but I like the idea of running an independant fuel cell for the dope. You can run C16 in the small tank, with a small FP- nad supply all the fuel you'll ever need to the solenoid without interrupting service to the motor. This keeps down the cost of expensive fuel pumps and you only give the motor leaded gas when you spray- which helps the O2's stay alive.
I know there are several people that have done this with success- I'd look into it..
Old 04-20-2004, 07:15 PM
taqwache's Avatar
ya, i think i am leaning towards the seperate fuel system instead of a 340/420L pump. i just got to call TNT and see if they have a fuel jet for this set up. i am sure they do.
Old 04-20-2004, 08:28 PM
1QWIKZ's Avatar
dude i found a cheap way to spray that much..oh oh, wait a minute, i already bought that TNT F4 kit with the warmer for $775.
Old 04-20-2004, 10:12 PM
Moderator
BADZ's Avatar
(1 bad Z) has this certain kit and he went 9.69 on a stock block!!!
Old 04-21-2004, 09:20 AM
Z284U2TRY's Avatar
What certain kit is he going 9's on a stock block? all stock internals?
Old 04-21-2004, 06:42 PM
Vents's Avatar
225 through the intake so far...
Old 04-21-2004, 09:09 PM
taqwache's Avatar
dam, every time i start thinking about which way to spray it, i come up with some figures and i always lean towards a direct port. money is kind of tight right now between buying a house, building up the LS1, restoring the 69, and converting my Z71 truck to straight axle. looks like i got to get a third job to come up with the money for the spray and support my hobbys. or maybe i should just pick up smokeing crack and become a junky (seems like it would be a cheaper habbit "lol").
Old 04-21-2004, 09:41 PM
1QWIKZ's Avatar
dont forget you still need the 12 bolt!!!
Old 04-23-2004, 05:20 PM
taqwache's Avatar
yea i know. i just keep ignoring that problem.
Old 04-23-2004, 05:25 PM
taqwache's Avatar
by the way 1QWIKZ when is the BQ going down. :
Old 04-23-2004, 06:34 PM
1QWIKZ's Avatar
definately tomorrow come over anytime
