Need advice for adding nitrous
Old 02-27-2013, 03:53 PM
Stippy17's Avatar
Default Need advice for adding nitrous
Well I guess ill describe my setup first. I currently have 423whp. The car is getting repainted as we speak, and then swapping out the built 4L65e for a low mileage 6spd, so it will have 450whp roughly.
2000 Trans Am - 60k miles
Stock bottom end LS1
5.3 Patriot Heads
.595 Comp Cam
Fast 90mm Intake
N.W. 92mm TB
Level 3 Monster Clutch
6spd Trans
Stock 3.42 Rearend
Racetronix Fuel Pump/Hotwire Kit
I'm looking to add a 100 shot plate kit for this summer, but only know the basics of nitrous. Any pointers in the right direction? I was looking at the N2O Outlet FBody kit.
The car won't be seeing much if any track time until I swap a 9in in. Currently it'll be occasional highway pulls. But I want a kit and system I can grow into as far as track use and bigger jets down the road.
Old 03-28-2013, 09:11 PM
slowpoke96z28's Avatar
What exactly are you wanting to know?
Old 03-28-2013, 09:48 PM
HCI2000SS's Avatar
I am not sure what you are asking either, but I run a NX wet kit on mine, and am about to hit it with a 100 shot. My build is very similar to yours
Old 03-29-2013, 09:59 AM
Neal@NitrousOutlet's Avatar
With your setup, you should be able to hit around 150-200 safely. You are going to want to make sure you pull out some timing with a tune or LNC2000, put the correct spark plugs and you should be golden. You fuel system should be good to 600-650 whp.
If you have any questions feel free to contact us.
Quick Reply: Need advice for adding nitrous
