how many stage dry sump? big lsx w/ 98+mm turbo
tryin to figure out how many stage dry sump guys with high hp lsx motors are using. i dont really know much about dry sump pumps.
I'm not sure what HP level or rpm your planning on running but I have a 427" LS engine that dyno'ed 670HP @ 6,900 RPM and I am running a 4-stage NRC Pro-Series dry sump pump and a 3.5 gallon capacity oil tank mounted in the trunk of the car. The dry pump was sized by the engine builder who also manufactures the pumps.
I run my car on road courses at track day events and have had good results with the 4-stage dry sump pump.
Here is a link to the website for NRC pumps... lots of info about dry sump pumps in general.
http://nutterracingengines.com/racin..._products.html
For high HP and high RPM motors 3 or more stages is the best way to go. If budget isn't an issue check out Dailey Dry sump, that's the setup I went with. Also check out ARE or Aviaid dry sumps.
