Just picked up a forged 383 lt1, what to check before install, power level for boost?
I recently picked up a 383 lt1 short block and have a couple questions about it. This motor will be used for street duty and will be a daily driver. Here is a description of the motor; Brand new forged balanced bottomend. Has oringed block, forged wiseco pistons 5009H3, decked, lined bored, new cam bearings, crank bearings and freeze plugs, four bolt splayed main caps with arp bolts, eagle forged crank and 6" h beam eagle rods. 9:5:1 compression ratio with stock lt1 heads and standard gasket.
I picked it up a few days ago and I'm waiting for time/money to install it. I want to go over the block to make sure everything was assembled correctly and is ready to go. Can someone walk me through this, or explain what I should check?
The other question I have is; how much power can this setup support? I am running 6 lbs of boost right now and am planning on pushing it to 12-15 lbs eventually.
Will it last as a daily driver? how much boost could be used and considered reliable, or how much rwhp can I make before I start to break stuff?
I probably have a few more q's but I'll leave it there for now.
Thanks for any advice.
I have a t56 with a decent clutch rated at 550 HP, and my rear end is a stock 10 bolt with 4.10 gears. I know the limit of my tranny is around 550 flywheel and the rear end is junk and will break regardless and then be replaced with a 9 inch. I could port my heads but with boost and a cam already I think heads on top of that will pass 550 flywheel. But all that aside what are the block and forged components capable of supporting?
X2 i agree! I bought my shortblock used with practically no miles on it and was going to just throw it together and put it in the car. Glad i decided not to as there was a lot of wrong as all the clearances were off and rings werent properly seated that im sure had bad blow by issues. Some of the bearing were already started to show premature wear too. So the morral of the story is dont trust anyones word as its alot easier to find out now then when its in the car.
Boosted motors WILL find the weakest link in your motor/combo. If the bottom end is set up PROPERLY then there's no reason that short-block couldn't handle 700-800fwhp at least.
agreed. go over the block make sure everything looks good, and even then youll probably do more damage to the tranny and rear then the engine itself... ifs its a daily i would really try to keep off the heavy foot until you beef up the rest of the drivetrain. just my 2 cents and the main reason i'm not going to be going boost anytime soon, going to buff up everything else first haha
