so the SES light back on
I havent hooked up to a scanner yet i have done the rear O2 already so if it is that again I'm going to get it deleted and remove my cats car still running fine for now.
yeah it was a question and my left bank is running lean so I'm going to proceed with find out why it is lean any one that might have suggestion to what is causing it i would appreciate it.
Thanks,William
Thanks,William
When's the last time you've changed plugs? Are they stock cats(how many miles)? That that chicken up to AutoZone and find out what the code it. There is a glossary of codes located in the newbie tech
don't know when the last time the plugs were changed i have had the car for six months only driven it for one due to all the title bullshit. it has 118,000 miles on the stock cats I'm going to to do long tubes and 3 inch cutouts with a true dual exhaust over the summer. i got the code it is bank one reading lean so I'm going to pull the O2 tomorrow and switch it with the other one and see if changes if not well i will see if i have fuel delivery issues.
Thanks,William
Thanks,William
Sounds like the same issue I'm having on mine. Changed 02 all rd and still throwing code. You're on the right track w changing exhaust out, pull all your egr too if u can spare the time. Then find someone to wipe all that from the comp and you'll b golden.
i know the exhaust is a big issue my car isn't loud enough for my liken and I'm going to do heads,cam,intake,and a good tune i would like to have 400+ horse before i decide whether or not I'm going to turbo or supercharge it.
Thanks,William
Thanks,William
I'm having the same issue on my 99 trans am. Its all stock but just had the motor overhauled due to a warped head and coolant in the oil. Anyways now mines saying bank 1 lean sensors 1&2 low voltage... I plan on doing longtubes / ory / ota catback when I get the money in a few months so I'd just like it to get me by for a few months. Anything you find out will be helpful so post it up! Thanks
