mustang swap throttle cable
which throttle cable are people using for mustang swaps. Not looking for any more fabrication work to make it fit. I think people are using the lokar unit. Not sure though. Going into a 87 mustang with 03 cable operated truck motor.
I used the 5.0 throttle cable. My intake had the throttle bracket, so I cut the bracket on the curved side almost where it bolts to the intake, rolled it toward the back of the engine a little at a time til it fit. Then I tacked it, removed it from the intake &welded it solid. I then drilled a hole to bolt the cable to the bracket. Looks as if it was made that way.
Figured id bump the existing thread instead of making a new one,one question.what are you guys doing in order to make the throttle body open all the way?mine only goes to about 80% with a aftermarket replacement cable
Lol 4 banger cable isnt even close with a stock intake.i heard mention somewhere of modding the throttle body linkage.i havent been awake enough to look but im guessing if you shorten the arm it should solve the problem
