Weak Point on Stock LS1 with FI?
Old 03-01-2013, 01:49 PM
maxpower_454's Avatar
Default Weak Point on Stock LS1 with FI?
What exactly is the weak point on a stock LS1 with FI? The hyper pistons? The rods, crank, and block seem to be able to take a ton of power but nevertheless there are failures on a stock LS1 bottom end.
Old 03-01-2013, 01:59 PM
LS1Tech Sponsor
hellbents10's Avatar
The rods are the first to go, and the pistons will not survive a miss on the tune up with big power.
Old 03-01-2013, 02:13 PM
Burken01's Avatar
Piston ringlands. High boost makes the rings touch because of the heat...
That's why a lot of guys gap the stock rings and add arp rod bolts while your down there..
Old 03-01-2013, 02:28 PM
sweet99ss's Avatar
#7 Piston usually gets hot
Old 03-01-2013, 08:21 PM
30th t/a's Avatar
Agreed. Pistons & rings will go before rods in most cases.
Old 03-01-2013, 09:26 PM
SSpeedracer's Avatar
Piston ringlands. I'm 8 for 8.
Old 03-01-2013, 09:53 PM
evo2ls1's Avatar
I will let you know in a few weeks, made 3 passes a few weeks ago and got a knock, just added a blower, but looks to be a rod
Old 03-02-2013, 10:23 AM
dans94z28's Avatar
At what psi or hp level are rods failing? A really good tune is really important from what I have read here to piston life for stock pistons
Old 03-02-2013, 10:29 AM
Yea that's why I went H/C first. I really didn't want to have an engine failure.
Old 03-02-2013, 10:42 AM
slow ride 02's Avatar
Even with H/C/I @ what HP will it fail?
Old 03-02-2013, 04:29 PM
Ryans99ls1's Avatar
generally you cant make enough power n/a to hurt the motor unless you are spinning to the moon.
The weakest point seems to be the pistons because this is where the most people are seeing failures. This is usually due to an off tune though and things got a lil out of whack and popped the ringland.
BUT if your tune is on, the rods will bend before a piston will break, which is probably where im heading because im going for more power this year.
Old 03-03-2013, 10:03 PM
evo2ls1's Avatar
yea NA not so much an issue, i dont mind 3 passes were great! car is amazing
Old 03-03-2013, 10:09 PM
lemons12's Avatar
600Rwhp is usually the point where it is just a matter of time for most.
Old 03-05-2013, 07:19 AM
skinnies's Avatar
This is the most quality reply in here, someone with real experience and knowledge of making stock shortblocks live at big power and knowing when they will fail and what will fail.
Ring gap isn't the problem, the TUNE IS THE PROBLEM. Not sure how many times us guys who make them live have to say this to people and they still don't get it.
Quick Reply: Weak Point on Stock LS1 with FI?
