T56 rebuild?
Old 03-01-2013, 09:02 PM
josephryan80's Avatar
Default T56 rebuild?
I recently got a t56 tranny that has been built supposedly, but the input shaft has some play in it so i know ill need a input shaft bearing. What i need to know if how can i tell if theres anything else that need changing just by looks or feel?
Old 03-02-2013, 04:28 PM
Hardcoresoldier's Avatar
inspect all the gears for chips/cracks/signs of wear. inspect synchro assemblies - especially the keys and blocking rings- for any signs of damage/wear. IMO, if you are going to start replacing bearings you should replace them all along with all new snap rings. If you are doing it yourself you will also need a bearing shim kit and a press (or something to use as a press). Oh, also inspect the main shaft for wear on the teeth.
Old 03-02-2013, 05:51 PM
thanks alot im still weighing the option of doing it myself, dont know for sure i just was wondering what parts for sure i would need to replace
Old 03-25-2013, 09:43 PM
Well im going to attempt it i ordered a input shaft bearing and am going from there hopefully wont be too bad
Quick Reply: T56 rebuild?
