LS3/Tremec Magnum/Mid motor plate
I have a CT525 LS3 and a Tremec Magnum trans. I am installing them into a car with a 1/4" mid motor plate. I want to run an LS3/7 clutch & flywheel but I'm not sure which slave cylinder/throwout bearing to run. I have a Wilwood master cylinder. I also need to know where I can make up the 1/4" from the motor plate. Any advise thanks....
