1977 Oldsmobile Cutlass Sedan (6.0 4l80E)
Old 03-02-2013, 10:50 PM
classiccaprice's Avatar
Default 1977 Oldsmobile Cutlass Sedan (6.0 4l80E)
Ok guys I have been around the forums for a while.. I spend most of My time here in the conversions and hybrids section. Anyway Im looking to build a very simple looking LS powered car. I chose a sedan because most coupes have been done and the sedan kind of fills the sleeper part of this build nicely.
Im looking for a simple swap I can take on Myself and this platform gives me plenty of room which hopefully will make for less fab work..
Drive train will be a 6.0/4l80E. Keeping fuel injected. Bone stock until I get all the bugs worked out. Maybe H/C and nitrous later.. I plan on buying a whole running donor vehicle.. 3500 express or a 2500 pickup and using every part I can.
Car will see track mostly qtr. mile but is mainly just being built for Holley LS fest and maybe a power tour or two...
My main question is .... Is this a cool swap or a waste of a LS powerplant?
Old 03-03-2013, 12:19 AM
i r teh noobz's Avatar
I like it. Should be a fairly easy swap.
Old 03-03-2013, 12:52 AM
CattleAc's Avatar
In my opinion...very cool swap...sleeper of the month.
Old 03-03-2013, 01:24 AM
Ok well I'm with it.. So thats 3 of 3... I will post some pics of the actual car in the am..
From what I hear a stock 4L60E is pretty weak.. Is this true for the most part?
I dont plan on going crazy with this build.. Maybe a max goal 400 whp... If I get there easily I may go for 500 eventually.. Do I really need a 4l80E?
Old 03-03-2013, 09:27 AM
ramairetransam's Avatar
thats cool as hell , do it .
Old 03-03-2013, 09:35 AM
formerly 2000blackcamaross (6-25-2013)
LSGUNSS's Avatar
If you are planing on getting a donor truck/van it will already have the 4L80E in it and I would use that. I know this car will weigh less than the donor but it will still be heavy with 400-500HP pushing it. I would go 80 and not think about a 60. I have a 60 in my S10 and when it goes I'm doing a 80 swap.
Old 03-03-2013, 11:10 AM
71403's Avatar
If it's pushing metal down the road and making noise it's never a waste!
Old 03-03-2013, 12:17 PM
Good point..
Thanks guys for the comments.. I think I may have found a donor. Im waiting to hear back...
Old 03-03-2013, 01:26 PM
LS1Tech Sponsor
psiconversion's Avatar
Agree with above. If you are going to be making 400-500hp I would recommend the 4L80E as well. Definitely going to be a sleeper. Good luck with it. Questions welcome.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 03-03-2013, 01:45 PM
tfi racing's Avatar
Sweet!Go for it,they'll never know what hit them!I'm with the others,it will NEED a 4L80E in the future,just do it now and be done with it.
Old 03-03-2013, 04:13 PM
Here is the actual car
87k miles all power
Ac still blows cold
Owned by an old lady since new
Some rust .... Ive been looking for a reason to buy a welder anyway
Trying to think of a project name
Old 03-03-2013, 05:30 PM
71403's Avatar
That's grandma-riffic. It's a win/win, you'll never have anyone whine about cutting it up and you've saved it from death at a demo derby.
Did that one get cursed with the 260 Olds?
Old 03-03-2013, 06:23 PM
Actually it has the 350 Olds which Im sure in its day would lay down a whopping 100 whp..
Old 03-03-2013, 08:43 PM
darren roar's Avatar
I agree with everyone its definitely sleeper of the month. Im subscribing.
Old 03-04-2013, 11:46 PM
Ok questions start.......
Now
I found a decent deal on 2001 5.3 100k ....so I will probably be picking it up soon..
Will all Year 4l80e transmissions work this engine? If not which will?
Also Ive been trying to figure out this whole mechanical speedometer conversion thing.. If I run digital gauges will I still need any kind of conversion kit or adapters for the 4l80e?
Those tailshaft conversion prices are a bit too much for my budget.. Ive been playing with the idea of using the stock th350 for now or atleast as long as I keep the granny gears in the rear end.. Opinions
I read so many conversion threads today My head is spinning...
Anyone running a vendor bought standalone harness?
Old 03-05-2013, 12:35 AM
71403's Avatar
Money and time wasted on a swap is inversely proportional to the amount of time you spend researching, seeing and asking what worked for others.
80E will bolt up to any LS motor. Half the pleasure of a LS swap is getting a modern OD trans that shifts when and how you tell it to, every time. Unless you have the not common dual pattern case you have a BOP pattern TH350.
Starting with a complete unmolested harness it's really not that hard to get working for conversion use. If you haven't found it already lt1swap.com is often referenced as a guide.
Old 03-05-2013, 06:03 AM
LS1Tech Sponsor
I agree with 71403, one of the under-appreciated aspects of the swap is that you can run the electronic overdrive transmission. I would recommend going with the 4L80E or 4L60E and if budget permits down the road, run a dual purpose tailshaft housing for your speedometer. Just my 2 cents.
Jon
PSI
__________________
Ebay Store
Old 03-05-2013, 12:30 PM
1970 ls_c10's Avatar
talk about sleeper!
Old 03-05-2013, 11:59 PM
Ok I picked up a 01 5.3... Here are some pics..
Yes its dirty... I will get some clean naked pics of it later this week...
Also picked up some f-body manifolds..
Ok so I have my eyes on a 1995 4l80e trans.. Is this gonna bolt right on?
Do I need a different flywheel or an adapter of some type?
Also need a driver side valve cover... If you have one laying around PM me...
Old 03-06-2013, 05:33 AM
aknovaman's Avatar
Aunt Matilda is a good name.
Quick Reply: 1977 Oldsmobile Cutlass Sedan (6.0 4l80E)
