Show me where you mounted ur turbos on ur 98-02 camaros
I'm trying to find pictures of 98-02 Camaro turbo setups where people have mounted the turbo(s) in places other than where they'd "normally" go? If that makes sense? Anyways. I had seen a picture somewhere where the turbo was mounted in the factory grill in the passenger side. Looked pretty sweet and i was just trying to figure out HOW to mount the turbo(s) in that same spot. "(s)' because i think a twin setup with the turbos mounted in the grill would look sick. Good location tho? IDK give me your input please. I'm really just interested in pictures with turbos mounted in different locations, like the grill for instance.
Thanks
Thanks
ls2 stock intake, the car has a 3inch cowl everything clears with alot of room to spare
just tuning on our local track, out the back door was around 142ish according to the logger at only 16psi and 14deg, just put all new front end on it and will be back up and going 2maro
