Lt1 ram air vs cold air!!!
Old 03-06-2013, 10:00 PM
transamkid1985's Avatar
Default Lt1 ram air vs cold air!!!
I have a 97 Camaro ss! It has built 355 ported n polished heads cc306 cam and a monster built 4l60e with 2500 stall. My predicament I'm in is whether r not I should remove my ram air n put a cold air intake on. N will a strut tower brace bolt up with the ss ram air still on there. I've done searches but all I come up with is ws6 stuff and there ram air is different from ours. Also can I switch to an ls1 lid without changing the hood and all that other stuff and it still be functional? It is an ss n I'd rather not do that I like the lt1 body style camaro's better than the ls1's! I don't like the catfish look lol. Any help would be great thanks!
Old 03-06-2013, 10:28 PM
hawk584's Avatar
ram air is a cold air intake system in it's self. ram air is speed induced air compressing on the leading edge of an object. with an inlet placed in the correct area, the compressed air that flows over, under and round is forced into the air inlet. the ram air effect, air starts compressing at about 60-70mph, also the aerodynamic wall. that's why MPG's is better best at about 55-65. I say keep the hood you have
Old 03-06-2013, 10:38 PM
O I was gonna do that I don't wanna get rid of my hood I like it I hate those ws6 style hoods for Camaro! Really any other hood besides a cowl. I wanna keep it original as possible on the outside. I just wanna know if I should get rid of my filter that sits on top of my intake n get a regular cold air instead r would it be more beneficiary to keep it ram air?
Old 03-07-2013, 05:42 AM
Rob
Rob's Avatar
Any CAI setup is better than the original SS setup. Buddy of mine ran a Honker back in 96 and was consistently .2 sec faster than stock. SS is too restrictive.
Old 03-07-2013, 06:09 AM
RamAir95TA's Avatar
Despite what most people think there is actually no "ramming" effect with "ram air." It's just visually appealing.
Old 03-07-2013, 08:08 AM
Village Troll
SS RRR's Avatar
Even Dave Hamburgler himself has admitted the ram air hood on a SS is ineffective. Besides the intake is a huge pain in the *** to work around during the most simplest of tasks.
Old 03-07-2013, 08:11 AM
93M6Formula's Avatar
They do make a strut tower brace specifically for 96-97 SS cars.
Old 03-07-2013, 11:59 AM
speed_demon24's Avatar
The water column gauge I used said different, unless you are talking just about the lt1 hoods that have the scoops too far back and too low to be in the air stream.
Old 03-07-2013, 12:03 PM
Village Troll
SS RRR's Avatar
The subject is understood to be about the LT1 SS Camaro.
Old 03-07-2013, 12:14 PM
Where can I get that at?
Old 03-07-2013, 12:19 PM
N I didn't know the ss setup was actually restrictive. If its true that it is robbing me of hp then I should change it. I thought it was helping! So now my question would be get an ls1 lid r a CAI setup?
Old 03-07-2013, 01:23 PM
Honestly I don't think it's anything significant to even worry about... Your "butt" dyno wouldn't even know if you did change it.
Old 03-07-2013, 01:29 PM
Have to do some google searching, I know somebody makes it but I can't remember who.
Old 03-07-2013, 01:41 PM
Lol but dyno!!! This might be a stupid question but just how is the ss ram air restrictive? It seems to me that it would be the opposite since its testing air directly forced inside.
Old 03-07-2013, 03:31 PM
RamAir95TA's Avatar
Because with the hood scoop entry being so low on the hood the air velocity at the level of the hood is significantly slower than higher up off of the hood (Google "boundary layer"). At the level of the hood the air velocity is actually ZERO. Velocity proportionally increases the further off of the hood you go but the inlet for the hood is well below the free stream. Coincidentally for this reason, this is why you see many high HP drag cars with the hood scoop 12-18" above the hood.
The SS hood has two 90-degree sharp bends in it (which is restrictive and turbulent), plus it sits on top of the engine. Many people see higher IATs with the SS intake as well.
Old 03-07-2013, 03:34 PM
It's mostly because it has to go through quite a few turns before it hit's the throttle body. Pretty much a "U" shape. That slows down the speed of air coming in but I still don't think it's that big of a deal on a bolt-on or mildly upgraded LT1. There's also a baffel in the scoop to prevent water from going in that's kind of a hinderance. The WS6 hood has it too. It's still and improvement over the Z28, Base Formula, and Base Trans Am intake.
Old 03-07-2013, 03:36 PM
EDIT :^^^^ He explained it a lot more technically.
Old 03-07-2013, 04:15 PM
Yea he did thanks I understand it a little better now. But this raises another question if they r that restrictive why do ss's have more hp from the factory than z28's! R ws6's more than trans am's? I know there is like a 10 hp difference between them on ls1 cars but idk if it is the same for lt1's r not. N which would be more beneficiary to me? A regular CAI r the ls1 lid?
Old 03-07-2013, 09:38 PM
blk97z28's Avatar
Got me a langinfelter (sp) CAI for like 150$ and works great.
Old 03-07-2013, 09:43 PM
RJDio's Avatar
Tearing all the baffles out of a WS6 hood, putting weather stripping around the hood ports and putting in a Volant would make it more of a "Ram Air" since there is nowhere else for the air to go, that is what I did and my mind is telling me I've gained 50rwhp while my car is telling me "dream on loser"
Quick Reply: Lt1 ram air vs cold air!!!
