Looking at buying a set of new LS3 heads.
I was thinking for the set up I want to do I could buy a set of LS3 heads and just port those, and it would be a more cost efficient way to do a head swap, considering i can get complete LS3 heads for $700. The cam I'm going with is the TR 232/224 cam. Does this sound like a combo? Any suggestions and insite are appreciated.
Thanks in advance,
Endrance
Thanks in advance,
Endrance
What engine is this going on? Supporting mods...any info you can give will help get you more accurate answers.
Don't just throw parts at a motor and expect it to perform. Planning out each and every mod then planning the part choices to beat suit your needs and complement each other is the ONLY way to build a performance engine.
Ask all the SBF guys what happens when you just throw parts at and engine. You make ~280rwhp and it cost $2500 lol
Forgot my sig doesn't show when I post from my phone. These will be for my LS1 on my formula. I'm avoiding throwing parts on the car and rolling the dice by posting on here. I don't like throwing away my money (without seeing results anyway). The plan on the car is to do full bolt ons with heads and cam. It's my dd so I don't want to get crazy.
I'm on my phone too so I wouldn't have seen it anyways. Lol
If you have a stock bottom end LS1 then the LS3 heads won't be for you. The intake ports won't match up I know ; I believe you'll need the LS3 intake manifold, fuel rails, and TB, then you'll need to convert your car to "fly by wire" and not use a throttle cable. Furthermore, the LS3 heads were designed for a 4" bore or larger.
Yes you can use LS3 heads on a stock bottom end LS1, but IMHO you'd be better off budget wise to use heads specifically made for the LS1. It'd be cheaper, easier, and make similiar power as the LS3 top end conversion.
I hope this helps and I'm no expert at all so if I'm wrong about anything I do apologize.
LS3 heads will bolt onto your LS1 but the valves will hit the cylinder wall, they need a 4.000 min bore, your LS1 is 3.898. Your best bet is to get ahold of company who knows LS stuff and can get you a head n cam package together designed for what you want out of the car and your goals. Examples: Texas speed, advanced induction.
You need to either call a sponsor and have them help you pick out a head cam kit and required supporting mods/bolt-on's or spend the next 2-3 weeks researching what you want/need to buy and how to put them on. So far you plans have 3 different problems, 1 your trying to pick out a head cam package for a car with no bolt-on's or supporting mods, 2 the heads and cam you want are a complete mismatch, and 3 you can't put LS3 heads on a LS1 the bore is to small. Also is your car a M6 or A4.
I realize all of that which is precisely why I'm posting on here, to get insight so i can make the right choices when the time comes. The car is an M6.
Feel free to give us a call, Private message, or e-mail. We'll be more then happy to help you find the best set up for you, and our prices are pretty damn good as well!
As stated earlier in the thread, the LS3 heads will bolt on, but they wont clear the cylinder walls. Fortunately, there is a huge selection of heads for your engine that will work, and work great as well.
Thanks,
Kyle
Thanks,
Kyle
Also, they do make cable tb's for ls3 intakes.
