Nitrous with a 6 speed
What is the best way to install a kit on a 02 WS6 with a six speed. Normally you would have the micro switch on the throttle plate but with the manual trans. would i need to use a 2 part switch and add one to the clutch pedal? Options please on what you guys are doing.
You will need a RPM Window Switch for sure. It will only alow the nitrous to come on during whatever "window" you have set. That way, in case you miss a shift, the nitrous won't engage past a certain RPM.
I've been doing a lot of research lately too, as I'm new to nitrous and have a M6 car too.
