Won't run with MAF plugged in
Old 03-07-2013, 06:22 PM
kainedogg's Avatar
Talking Won't run with MAF plugged in
I installed a '00 6.0 in my '84 C10 and actually got it started and even drove it today (around the block)
When I plug in the MAF it immediately dies, assumed it was a bad one and swapped another one in but exact same thing. Any ideas?
Also since I am using the original TH350 how would it know when to shift? Do I need to find some way of hooking up the original kickdow
Old 03-07-2013, 06:57 PM
LS1Tech Sponsor
psiconversion's Avatar
Kickdown and vacuum modulator should be hooked up to get it to shift.
What MAF are you using? Is it the correct one for the tune?
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 03-07-2013, 07:07 PM
aknovaman's Avatar
Chk for +12v between pink and black wires at MAF harness connector with ignition switch ON. Likely you don't have it so maf does nit produce a signal to pcm, so truck won't run. Also don't plug in maf with engine running. Turn ign off first.
Old 03-07-2013, 08:00 PM
the_merv's Avatar
Big difference between MAF and no MAF on a vehicle..is it tuned or still factory tune?
Old 03-07-2013, 08:19 PM
kainedogg's Avatar
Cool C10
Thanks for all the input gents.
Jon
PSI
It is a stock MAF. Actually had it programmed to run a 100mm, so when the truck would not stay on, I swapped it out for a factory MAF but got the same results.
Will check in the morn & be more mindful when I plug it back in. TY
What do you mean friend? Truck is on a factory tune except for the TH350 & 8k pulse for the Dakota digital speed sensor.
Old 03-07-2013, 09:18 PM
aknovaman's Avatar
Verify electrical first. Even if maf ttable is totally off target, generally it won't die immediately.
Old 03-07-2013, 09:35 PM
ls1nova71's Avatar
Is the MAF in the intake tube? If you just got it running and don't have an air intake plumbed up, and just plug in a MAF, it will die. It needs to have the air intake going through it.
Old 03-07-2013, 09:36 PM
LS1Tech Sponsor
Agree with Novaman. Make sure the pinout is correct.
Jon
PSI
__________________
Ebay Store
Old 03-07-2013, 09:38 PM
ls1nova71's Avatar
On the transmission, you need the vacuum modulator hooked up for it to shift. On a 350 turbo, the kick down doesn't need to be hooked up, but it will make the truck feel like a slug at times, since it won't be able to down shift when needed. You could manually downshift it, but that gets really old really fast.
Old 03-07-2013, 09:55 PM
kainedogg's Avatar
Jon
PSI
As soon as the sun comes up, I will check it with my voltmeter, maybe post a pic as well.
I think I may have tossed the hose in the bed of the truck back when I just knew I was getting a 4l80e.
The MAF is indeed in the intake tube with the arrow depicting flow pointing towards the engine.
If I have 12+ at the pink or black, I'll go from there.
Old 03-07-2013, 10:00 PM
kainedogg's Avatar
On a side note I cheaped out and modified the original throttle cable to attach to the outside of throttle wheel instead of following the groove, so I basically just eliminated the mounting point for the throttle kick-down....too clever for my own good
Old 03-07-2013, 10:17 PM
kainedogg's Avatar
I had 12vs from the pink wire (positive probe inserted in connector and negative probe grounded to frame)
How would I test the black wire? Don't want to fry my ecm while basking in ignorance.
Took a pic of the connector and tube as well. Figured if you guys are helping might as well burn the midnight oil...literally.
Old 03-08-2013, 12:44 AM
stangtrader's Avatar
Ground you can either ohm or test the harness for a brake.yellow wire iirc is a 0-5v ref for the pcm.one thing tho.i recently helped some one on a swap with the same issue and it turned out to be a bad maf.
Old 03-08-2013, 05:41 AM
aknovaman's Avatar
Yellow is MAF freq output. Black is ground. Pink is switched ignition. Other two wires are inlet air temp sensor output.
Old 03-08-2013, 06:04 AM
kainedogg's Avatar
I swapped in a different MAF and still got nothing.
My harness has 1 pink, 1 black, 2 grey and a brown. I assume the brown is the MAF freq. So how exactly do I check the ground wire? As stated the pink has 12v.
Old 03-08-2013, 06:31 AM
LS1Tech Sponsor
You can check the ground by putting one tester probe to power and the other to the black wire, it should show batter voltage.
The two gray wires are IAT.
Jon
PSI
__________________
Ebay Store
Old 03-08-2013, 06:54 AM
kainedogg's Avatar
If the original 100mm maf is bad and I plug in a standard one, would it still not work because the ecm is programmed to recognize the 100mm? Just wondering since I plugged both in and it still cutoff.
Old 03-08-2013, 06:55 AM
kainedogg's Avatar
Jon
PSI
Thanks Jon. I will do that now.
Old 03-08-2013, 06:58 AM
kainedogg's Avatar
Ok:
Pink wire: 12v
Black wire: 12v
Yellow(freq) 5v
Old 03-08-2013, 08:27 AM
LS1Tech Sponsor
BP Automotive's Avatar
Originally Posted by kainedogg
Ok:
Pink wire: 12v
Black wire: 12v
Yellow(freq) 5v
Im guessing you have 12v between pink and black? Just trying to clarify that you do not have 12v on the black wire too.
What you checked is checking out, the PCM will uses all the sensors combined to make a determination on how the vehicle is running. My guess is you probably have a conflict between your MAP and your MAF readings. You should double check your MAP sensor and your MAP pinout. Glad to hear you are using a multimeter and not a test light!
The MAP Pinout is as follows
A Black or Orange with a black stripe. - Low Reference
B Light Green. - Map Sensor Signal
C Gray - 5 Volt Reference.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Quick Reply: Won't run with MAF plugged in
