Gold glitter in oil after head swap
Old 03-09-2013, 06:32 PM
its turbo time's Avatar
Default Gold glitter in oil after head swap
I just changed my oil after swapping my heads and it looked like I had some gold looking glitter in my oil as I was draining the old oil back into the oil jug.
It appeared as if the glitter was coming out of the used filter after I put it in the drain pan with the rest of the oil.
The car still has good oil pressure, and I drove it about twenty minutes and checked the dipstick and there was no glitter on it.
I put new PAC 1218 valve springs in the heads and they almost have a goldish plating on them. The guy who ported my heads thinks that it could be from the valve springs.
The car seems to run great, no knocks or ticks and has great oil pressure. There was no gold on the magnetic drain plug either. The usual amount crap was on there but nothing out of the ordinary.
What do you guys think??
Old 03-09-2013, 06:52 PM
ls1 1990 VN's Avatar
Bearings!
Old 03-10-2013, 12:50 AM
Super Hulk Smash
JakeFusion's Avatar
Yup, bearings. Or your engine sucked in Edward from Twilight.
Old 03-10-2013, 05:02 PM
I cut open the oil filter and didn't find any metal in there surprisingly
Old 03-10-2013, 06:08 PM
WKMCD's Avatar
Send the oil off for analysis. Not buying the color coming off the springs. There's nothing in the heads that will give off a gold color. Bronze guides?
Old 03-10-2013, 06:52 PM
litle88's Avatar
^^ yup bearings or also thinking about the bronze guides.
Old 03-11-2013, 12:13 AM
C5natie's Avatar
I got scared when I saw something similar after I did a cam and head swap on my LS3. Turned out it was the break in oil and lube since I did use a lot of it. Also new components will release some material at first. I changed the oil at the first 500mi and then at 1000mi. oil is regular now and pressure has remained constant. Get it analyzed first, doesnt have to be a worst case scenario.
Old 03-11-2013, 08:39 AM
I think I figured it out, my dad used that drain pan a week ago to drain the oil out of his buddy's dirt bike that had grenaded it's transmission.
Old 03-11-2013, 09:38 AM
WKMCD's Avatar
LMFAO
Old 03-11-2013, 09:46 AM
Yeah I know, I about had a heart attack over nothing
Quick Reply: Gold glitter in oil after head swap
