New C6 Corvette Hydraulic Motor Mounts
Category: Accessories
Price: $75
Location (State): PA
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9
LS Engine?: Fits LS Engine
I bought these mounts new, slightly shortened the studs on one side of the mount (basically just ground off the non threaded part on the one side). I had to do this for them to fit in my 240z engine swap.
I measured the length of the threads on each side of the mount in the pictures. The studs are M12.
I did have the mounts installed on the 240z, the motor was never even fired up with them in the car. Because the exhaust clearance is so tight I decided to go with Hinson C6 polyurethane mounts.
Hopefully someone can take these oem mounts off my hands. I trimmed almost nothing off the threaded part of the studs, so these should still work well on a C6 vette. I read that C5 vettes can use these mounts as well, that they are the same, except the C5s are solid rubber not hydraulic.
These are also good for engine swap mounts as well.
