1" setback plates ???
Old 03-11-2013, 03:47 AM
jaywill's Avatar
Default 1" setback plates ???
will my 350 trans be able 2 stay in the same place on my 79 malibu ??? just like it is now w/350 engine.???
Old 03-11-2013, 09:50 PM
Blackpony's Avatar
I ordered the "stock" location plates for my c10 swap. Once installed it moved the trans about an inch or so forward. I ended up having to order 1 inch set back plates to get it right...
Old 03-11-2013, 10:01 PM
badazz81z28's Avatar
Yup, The LS engine is not as long. I have one inch setbacks and the trans is still more forward than it was with the SBC.
Old 03-12-2013, 03:33 AM
jaywill's Avatar
thanks
Old 03-13-2013, 03:36 AM
jaywill's Avatar
Default i just ordered these..
http://www.summitracing.com/parts/trd-4595
Old 03-13-2013, 03:39 AM
eroc022's Avatar
Good luck with the transdapt, when I tried putting them on mine the mounts didnt line up... others have had success..
Old 03-13-2013, 05:26 AM
jaywill's Avatar
I hope like hell they fit... so I won't be wasting my money... I'm going to use the factory clamshell on the plates
Old 03-13-2013, 12:46 PM
Blackpony's Avatar
The ones I have on there now are transdapt. It was a mf'er to get the bolt in. I ordered a set of set back plates off eBay this time. Hoping to put them in this week. Ill let you know how they fit.
Old 03-13-2013, 01:51 PM
jaywill's Avatar
what the bolt holes dont line up ?
Old 03-14-2013, 09:51 PM
Blackpony's Avatar
The long bolt that goes through the rubber mount and upper mount, when I went to bolt it in there was about a 1 inch off set from it line up. Had to pry the rubber to get the bolt in..
Old 03-15-2013, 03:44 AM
jaywill's Avatar
i'll luk how it goes..
Old 03-15-2013, 07:55 AM
Blackpony's Avatar
My motor mounts were kinda worn so its possible that they were sagging a little thus causing the alignment issue.
Old 03-15-2013, 12:18 PM
bczee's Avatar
if you notice on a SBC vs the Gen III/IV/V engine. The missing 1" is due to the rear bell housing flange.. due to the new cars engine bay being smaller.. GM shorten that area so they could fit them into a more compact engine bay.
That is about it for why you move the engine back 1" to meet up with the stock location of a older cars transmission flange location. (or trans up 1").
There is no one reason to use one plate location or another location IMO.. just move it where it works best..
BC
BC
Old 03-15-2013, 12:25 PM
jaywill's Avatar
Tru...
Old 03-15-2013, 02:41 PM
BC
BC
Actually...if you don't match up the engine location, your driveshaft length will be off and possibly the bolt holes for the transmission crossmember. Depending on if you have a manual, the shifter location may be affected.
Old 03-15-2013, 02:52 PM
bczee's Avatar
Yes.. that is a taken if you move it.. I should have stated that. I think I stated some of the same in aonther recent post out there a both plates.... .
Neither of my swap (chevelle or nova) are in any standard or 1" setback locations. Both are have either modified frame stand location or plates engine location changes. Drive Shaft are custom.
BC
BC
Old 03-15-2013, 09:25 PM
toxic99's Avatar
I used carshop 1" set backs on my 67 camaro and my th400 fell right into factory location on the xmember. I realize it is a different car but as others have said, 1 inch back plates are designed to put the rear of the ls engine in same location as if it were a sbc.
Old 03-17-2013, 09:15 PM
Blackpony's Avatar
Installed my 1" setback plates today, trans is still about 1/4-1/2 inch forward but that is much better. The trans now bolts to the factory crossmember
Old 03-18-2013, 03:29 AM
jaywill's Avatar
Default i had mod my pass. side ..driver side fit great
Quick Reply: 1" setback plates ???
