What do I need fuel system for 1000HP s480 Turbo
Im trying to get everything together for my fuel system, here is what I already have.
95lb injectors
Edelbrock fuel rails
Aeromotive Eliminator pump
Aeromotive 13101 FPR
Aeromotive filters
(Also have Meth Kit)
This is going in my fox with a sumped tank. So first off im thinking that this fuel pressure regulator is not going to work because of the -6 return line?
Im thinking -10 lines both supply and return????? Anyone with high HP running that FPR? The instructions on the aeromotive eliminator say i should run the 13110 ... pshhh over 300 bucks for that thing.
95lb injectors
Aeromotive filters
2nd that. Magnafuel all the way. I have there 4303, 10 feed/return, regulator and filters.
It all falls back on what fuel you are using.
