Crazy Question! How to drain G8 gas tank filled with 89 octane
I need to drain a gas tank full of 89 octane to refill it with 93 octane. I just installed a a Procharger and it needs to be run and tuned on 93. Before you ask, I wasn't the one who filled it with 89
In the past on my 98 SS I have hooked a hose to the fuel rail and turned the engine on to drain the tank. I cant do this on the G8 because I cannot run the engine since it has not been tuned yet. With the key turned to on it still doesn't work. It seems like it has a set time to build up pressure and then it shuts off.
Does anyone know of a way to trick the fuel pump to run so I can get the fuel out of it? It has half a tank and I will be happy if I can get most of it out.
