Need to fix broken male socket - PT1486 connector
Old 03-12-2013, 11:19 PM
jmarsa's Avatar
Exclamation Need to fix broken male socket - PT1486 connector
I'm hoping this is the rght section.
While working on my GMC I stupidly ripped a wire out of the back of this type of connector
How do you repair this? Is there a special dealer tool that's needed? Any advice is appreciated.
Thanks in advance,
--JMarsa
Old 03-13-2013, 12:10 AM
jmarsa's Avatar
Looks like I need a "terminal release tool". Still trying to figure out which one.
Old 03-13-2013, 07:59 AM
Save the manuals!
wssix99's Avatar
You need a bunch of stuff:
- The terminal release tool to get the old terminal out.
- A new crimp terminal to replace the one that pulled out.
- A special crimper to attach the new terminal.
The path of least resistance to do a good repair is probably to go to a dealer. All GM dealers have a terminal repair kit, which has all of these pieces in it. (I've been to some dealers where the guys on the floor didn't know they had one - but they do. It might be buried somewhere.)
You can also try to back woods the repair with a paperclip as a release tool and needle nose pliers to re-crimp the old terminal, but it will be a PITA and probably won't be a lasting repair.
The details on the terminals are in this catalog. (It looks like you have a GT150 connector.)
http://delphi.com/pdf/contact/brochu...balCatalog.pdf
Details on the release tool, crimper, and repair instructions for each terminal are here:
http://www.weber.edu/wsuimages/autom...%20Booklet.pdf
Old 03-13-2013, 08:37 PM
jmarsa's Avatar
wssix99, you rock, thanks!
I though this was the connector:
http://acdelcotechconnect.com/pi/wir...6-15306424.jpg
Anyway, after reading the docs you referenced I decided to take your advice and take it to the dealer. Usually I'll spend to money on tools and do it myself but I wanted to make sure I didn't have any issues.
Thanks for your input.
--JMarsa
Old 03-13-2013, 11:01 PM
Save the manuals!
wssix99's Avatar
Originally Posted by jmarsa
It might be. GM sells the connectors as pigtail assemblies where you can splice all the wires going to the connector. IMO - Just fixing the terminal is a lot more solid than 5-8 splices.
But... If the dealer pulls some BS and tells you that they need to charge you $170 for a one hour minimum on an electrical tech to crimp one terminal, it might be more cost effective. Hopefully you have a good/fair dealer to work with locally!
Quick Reply: Need to fix broken male socket - PT1486 connector
