Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Replaced clutch/flywheel/slave = HARD pedal
Old 03-13-2013, 07:39 PM
jclayc's Avatar
Default Replaced clutch/flywheel/slave = HARD pedal
I'm 2/3 through installing a LS7 clutch, flywheel and LS7 slave in my 05 V. No big problems during the process. After re-installing the trans, driveshaft & shifter, I pushed the clutch pedal expecting it to go to the floor and it is hard. I mean, zero movement. The slave is not connected at all and the bleeder is open.
When I turn the driveshaft by hand, the wheels turn at the back and the rear trans yolk turns too. When torquing the pressure plate bolts, the engine turned over, so I know from the pressure plate forward is turning. That says to me that I've got a problem with the slave or the way the two are mated - I think? Sliding the trans back onto the engine went ok, since I have a fancy trans jack (a must have) so I didn't feel anything go wrong during that process.
Or, of course, I could be prematurely judging things and should just bleed the clutch, etc. and check again, but I seem to have the opposite problem of most people.
Thanks for your help!
Old 03-13-2013, 08:04 PM
01_SuperSlow's Avatar
Why is the slave not connected?
Old 03-13-2013, 08:18 PM
DMM
DMM's Avatar
I was thinking the same thing.
Old 03-13-2013, 08:28 PM
punishmentcycle's Avatar
Smh hook the damn slave up.. There is a check valve in the connector so of course the peddle isn't gonna move
Old 03-13-2013, 08:44 PM
jclayc's Avatar
hooked up, no change
a suggestion I've been given: the clutch fork isn't centered correctly between the studs on the slave
Old 03-13-2013, 08:50 PM
DMM
DMM's Avatar
What exactly are you working on again?
Old 03-13-2013, 08:59 PM
jclayc's Avatar
2005 CTS-V
i was asking the same thing about the clutch fork suggestion but wanted to read up more - didn't make sense
darkman sent me this: https://ls1tech.com/forums/lt1-lt4-m...tch-pedal.html
Old 03-13-2013, 09:05 PM
jclayc's Avatar
I wanted to test it with and without the slave connected in a step by step process, not thinking about the check valve.
Going to check for binding issues now...
Old 03-13-2013, 09:23 PM
jclayc's Avatar
got it - connection wasn't good between the master and slave... thanks for your responses!
Old 03-13-2013, 09:31 PM
DMM
DMM's Avatar
Old 03-13-2013, 10:13 PM
That was going to be my next suggestion, to make sure it snapped in place.
Glad you figured it out
Old 03-13-2013, 10:55 PM
Now go beat the **** outta it.. Lol. The cars gonna rev 10x better
Old 03-14-2013, 08:44 AM
jclayc's Avatar
I'm clearly not afraid to ask stupid questions so here's one more: did I screw up like I think I did by putting a little grease on the input shaft?
Old 03-14-2013, 08:50 AM
Deff gonna get on the clutch disc but should burn off fairly easily.
Old 03-14-2013, 08:54 AM
NIKDSC5's Avatar
Yup, and at this point you just gotta hope the grease has no chemical reaction with the clutch material to cause a failure. I highly doubt it so you should have nothing to worry about.
Old 03-14-2013, 08:57 AM
jclayc's Avatar
I haven't even turned the engine over... Figure I might pull the trans and wipe it off before it slings grease around
Quick Reply: Replaced clutch/flywheel/slave = HARD pedal
