Drag Racing Tech - Will an aftermarket torque arm help my 60ft?
StevieZ
04-20-2004, 06:55 PM
I'm running the stock TA right now and was wondering what kind of a difference an aftermarket one would make
NastySSoo
04-20-2004, 07:04 PM
It didnt improve mine, but when I finally broke the stocker I went for a stronger version. Maybe with the recent install of my drag shocks on the rear Ill see a difference. Going to the track tomorrow, stay tuned! :drive:
Coach 02 A3 Z/28
04-20-2004, 08:20 PM
One word. MADMAN!!!!!!!!!!!!!! :devil:
Coach
14u2nv
04-20-2004, 11:06 PM
Coach
COACH...has MADMAN come up with one for a f-body with a M6 and y-pipe set-up yet?
Coach 02 A3 Z/28
04-21-2004, 03:03 PM
Yes. Give him a call. :nod:
Coach
Nine Ball
04-21-2004, 03:20 PM
Aftermarket torque arms will help once you have reached the limits of tires. If you aren't running true drag slicks, try those first.
Pro Stock John
04-21-2004, 03:26 PM
An aftermarket t/a can always help, what does your car 60ft now? You race on drag radials?
14u2nv
04-21-2004, 08:05 PM
Will a good torque arm help even if ET STREETS are used?
Kent1
04-21-2004, 08:09 PM
In my opinion, yes it would. Gives you another adjustment to dial in. Without it, you have none. True some don't use it, but there is no room for adjustment either. I like random technology TA. cheers.......... :nod:
timelord
04-21-2004, 11:17 PM
Yo !!! Stevie,,how you doing my friend,by the looks of your sig you have been busy,what was your best time last year?
I have the BMR Adj and don't know if it improved my 60Ft,but the car is a good bit heavier and my 60's are no worse,but the peace of mind is ,,,,PRICELESS !!!!! :drive: :nod:
hawaiiboysz
04-24-2004, 07:34 PM
almost 300 bucks for a TA and shit to show for it I think I felt more on road handling improvments then 1/4 mile racing improvments. no wheel hop though but I installed LCA's and SFC's. handles fine but not faster.
Pro Stock John
04-24-2004, 11:57 PM
An afterrmarket torque arm should be done after you do lca's, drag tires, and drag shocks.
An aftermarket torque arm will allow you to put some positive pinion angle in since some stock torque arms are cocked up a bit.
