LS 2 6 pin TB to 8 pin harness
Like the title says I'm putting an TBSS intake and TB on my engine, the TB has 6 pins and the harness, 04 5.3 harness has 8 pins. Does anybody know which wires I need to re-pin the connector or where I can get an adapter harness?
I have an 05 harness with the 8 pin tb right now. It runs and drives fine, just looking to upgrade to the larger 90mm 6 pin tb along with an edelbrock intake. What else is required for this swap? Tb, tac, and pedal or can I use my current truck pedal and tac module?
The following users liked this post:
Nicholas Dargaville (12-22-2020)
I think this might be what you need. I called PSI for my swap harness. I'm going with an LS3 intake on an LQ4. It's a 6-8 pin harness.
It's the torque rush x-link. It's a little pricey, but I was told it does the trick.
http://www.torquerush.com/x-link.html
My understanding is/was that you need this. Unfortunately my car has spent the last year and a half in the shop getting done work done and hasn't been fired up yet. Hope that helps.
http://torquerush.com/x-link.html
Snake eater
I just got an email from snake eater. They used to make a retrofit throttle body but “it wasn’t popular” so they quit making it
