60lb injectors
I would just do 80# injectors if I were you. It gives you more room to grow instead of being so limited and there really isnt much of a price difference between the 60# and 80# injectors, so you might as well just get the 80's.
UNDER PRESSURE MOD
I need to do some work on my fuel setup as well. I have twin 255's in tank, run through the factory line to a set of custom fuel rails and 60# injectors. I know I'm already at about as far as I can go with this setup. I guess it's time I step up to a dedicated line and regulator as well.
I'm running~15psi of boost and seeing north of 85% idc, but I'm also spraying a good bit of methanol/water.
I said that at one time as well. Now I just came to terms that my car will never be fast enough or look good enough lol. I understand you have an end goal, but why not just spend a few more dollars, literally, to get something you know will work instead of guessing and hoping the 60# injectors work.
You can find good deals on ebay. Just make sure you get them with the right connector.
