e85 fuel pump for nitrous
Old 03-16-2013, 06:55 PM
slowswb's Avatar
Default e85 fuel pump for nitrous
I'm looking for fuel pump that will work for e85 and won't loss fuel pressure pulling fuel from rail on 200 shot I was going to use a am340 i know it not e85 rated but people have use them. Its for a 04 silverado returnless fuel system.
Old 03-18-2013, 05:07 PM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
Automotive says that you can run E-85 in that pump but they recommend proper filtration of it (other than stock I assume) and that the filtration needs to be serviced every 10 run hours.
Also they do not recommend running that pump on a return-less style fuel system without modification to the fuel system.
Here is a link to there FAQ on that pump.
http://aeromotiveinc.com/tech-help/f...th-fuel-pumps/
Personally I do not know of a fuel pump that I would recommend you run trying to pull that much off the rail being that it is a return-less style setup with E-85 . I would have to say with that much power either use a stand alone tank or possibly switching to a return stye fuel system. If I were you I would call Racetronix and see what they recommend.
Trey
Quick Reply: e85 fuel pump for nitrous
