magnaflow dual setup????
I'm trying to quiet my car dwn I'm tired of my bullets I'm running dials so I wanted to run magnaflow stainless straight thru exhaust and want to see what yall running with a dual setup with dual tired of the load exhaust
This is a cold start...it is about 20 degrees F.
Idle is at 1100 rpm. At 20 or secs, idle settles to 800. At about 43 secs, you'll hear the ECM switch over to closed loop, which takes about 14 secs. Later, rpms are held at 2000 for a few secs. Then, a rev to 3000, & also to 4000.
I was hesitant to go farther, as the block was still cold, & oil pressure still high @ 70
While the sound is quite full from the camera's position, it is subdued from the cabin, even with windows open, until under acceleration.
With the Magnaflows, I wasn't 'vibrating' for half an hour, after taking a spirited drive.
Listen with a headset to get the true sound.
