lt1 nitrous questions
ive never messed with nitrous before but im looking at getting a dry kit, and progressing to a 150 shot.
my question is, should I get a plate kit or a kit that injects the nitrous infront of the MAF?
it seems like that 2nd choice would be easier to setup and tune
LT1s do not use "through the MAF" dry systems...the PCM wil not add the extra fuel reliably
LT1 dry kits use the nitrous flow to force the fuel pressure regulator to increase fuel pressure which in turn forces more fuel through the injector when it opens for its normal duty cycle.
I would suggest not running a dry kit on the LTx platform...go wet and call it a day
alright thanks guys ill look for a wet kit.... how did you guys pull in the fuel for the wet kit? just tap the shrader valve or splice a tee into the fuel lines?
