Calculating fuel line size
Old 03-18-2013, 09:20 AM
mjollnir's Avatar
Default Calculating fuel line size
I will be installing new fuel lines on my body-off project corvette 1981
I need to figure out the size of the fuel lines (feed & return) to install.
I have checked the FAQ and found I need 51 to 65 lb/h injector.
But what about fuel line size? And should return line be smaller than feed line?
Old 03-18-2013, 09:29 AM
mjollnir's Avatar
I was thinking going for 5/8" / AN -10 tubing.
Old 03-18-2013, 06:57 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
For that you only need a 3/8" or -6 supply.
I typically run a -8 supply & -6 return for most applications under approx 1100rwhp as the cost between a -6 & -8 are very little.
A 5/16" return can sometimes cause elevated idle pressures due to line restriction, so I never go below 3/8" or -6 on the return.
Old 03-19-2013, 04:41 AM
mjollnir's Avatar
Will go for that, thanks
Quick Reply: Calculating fuel line size
